At a loss
Old Jan 4, 2016 | 02:56 PM
Highboy's Avatar
Highboy is on a distinguished road
Yes they have
Old Jan 4, 2016 | 03:03 PM
Highboy's Avatar
It takes a few times to get the gears engaged once it happens. Sometimes i have to use 4 wheel drive to get it off the road
Old Jan 4, 2016 | 03:05 PM
Highboy's Avatar
Keep in mind, this vehicle has a 6" suspension lift and sits on 35" tires. I've shimmed the tear axle to compensate for the driveshaft pitch
Old Jan 4, 2016 | 03:21 PM
odat's Avatar
well pressure on the shift points should be good - something in the transfer case or the rear differential is freewheeling
Old Jan 4, 2016 | 03:26 PM
Highboy's Avatar
Thank you for your help. I'll have a look at the differential. I've also swapoed out the transfer case when the first tranny did this
Old Jan 4, 2016 | 03:38 PM
odat's Avatar
I'll beat my head on this some more- post back with any thing you find
edit - check the linkage on the transfer case for wear or miss adjustment to see if it is shifting solid into 2WD
Old Jan 4, 2016 | 05:44 PM
Highboy's Avatar
Will do. Thank you
bryanmine
May 19, 2011 11:27 AM
user 1016
15
Apr 10, 2006 11:56 AM
medion42
Mar 16, 2006 10:18 PM
paul06
Jan 17, 2006 04:54 PM
the wood
Oct 29, 2005 12:48 PM
