Loss of power on 95 Blazer 4.3L
Old Sep 13, 2013 | 10:06 AM
Piero's Avatar
Piero is on a distinguished road
Default Loss of power on 95 Blazer 4.3L
Hello,
There is a problem on my Blazer now, it miss power ! The V6 roars, the transmissions works good, but no power...
Engine light is OFF.
I don't know where it could come from. Does anybody had a similar problem here ?
Old Sep 13, 2013 | 01:10 PM
Piero's Avatar
Oh, I've forgot to say my catalitic converter is noisy.
Old Sep 13, 2013 | 05:43 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
when my fuel pressure regulator started leaking i had very poor power, i also got 10mpg and black smoked real good at start-up. Usually a clogged cat wont let the engine rev high, i say usually just becasue there are always exceptions.
Old Sep 13, 2013 | 07:46 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
I had a similar issues on my 98 s-10 pickup the cat clogged up so bad even downshifting and flooring it the truck would barely move. So I unbolted the cat and started it up and ran fine so I knew it was the cat . Without exhaust flow it won't run.
Old Sep 14, 2013 | 02:03 AM
Piero's Avatar
Ok, tomorrow I'll unbolt the cat and empty it, and test.
Old Sep 15, 2013 | 12:34 PM
Piero's Avatar
I've dismantled the exhaust today. This is what there was inside the cata !
Some of these blocks of ceramic were inside the muffler... I think this is the cause of my loss of power.
I'm gonna do some welding... and put the empty cat on the car...
Attached Thumbnails Loss of power on 95 Blazer 4.3L-1186341_10151835167019420_2012047201_n.jpg
Old Sep 17, 2013 | 05:43 AM
Piero's Avatar
What do you think about an empty catalytic converter with 2 oxygen sensors ?? Does the engine work properly ?
Old Sep 17, 2013 | 08:25 AM
engine will operate fine, you will get a check engine light with your downstream sensors saying catalyst efficincy below threashold, or something like that. You definatly wont pass emissions.
Old Sep 17, 2013 | 12:49 PM
Piero's Avatar
And if I unplug the second sensor and put it on a support outside the cat... ?
Old Sep 24, 2013 | 03:29 PM
Piero's Avatar
I've tried with the sensor on and out the exhaust, it's almost the same. And no CEL. It just miss torque because my cat is empty.
I've tested my emissions on a gas analyser, the lambda is good , 1.02 .
rob2129us
19
May 3, 2012 01:59 PM
bryanmine
May 19, 2011 11:27 AM
AnAirbagSavedMyLife
Jan 21, 2010 11:23 AM
BrianSw
73
Sep 6, 2009 09:16 PM
ryn9909
Jul 21, 2008 05:01 PM
