Low Oil Pressure on 2001 S-10 V6
Old Jun 9, 2010 | 06:03 PM
Reefar_co's Avatar
Reefar_co is on a distinguished road
Cool Low Oil Pressure on 2001 S-10 V6
Today my check engine light came on and my oil pressure is showing very low. Oil level is fine...and there does not appear to be a leak anywhere.
I am thinking oil pump but I am not sure about that.
Old Jun 9, 2010 | 06:19 PM
Define really low... GM states minimum hot oil pressure to be 8psi at idle and an increase of ~10psi for every 1000RPM up to around 60psi.
Have you checked the codes?
Old Jun 9, 2010 | 11:37 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
If it's really low from what you're used to I'd double check for a leak at the sender. Since it sits on top in the back you may not notice any drips for a while. Others have had this problem and after REALLY looking they found their sender was leaking. Doesn't cost anything to be sure.
Old Jun 10, 2010 | 10:58 PM
Reefar_co's Avatar
here are the codes I got:
P0410
1 Circuit relay defective or fuse open
2 Check connector and wiring
3 Air pump defective or hoses blocked
musclecar70sfan
Sep 30, 2010 06:58 AM
rohde782
Oct 8, 2009 08:36 PM
Bigblue
Oct 1, 2009 01:43 PM
noom14921992
Nov 9, 2008 05:16 PM
s10_1997
Mar 28, 2008 02:30 PM
