Low voltage issue from underdrive pulleys, will be taking them off.
Old Aug 22, 2013 | 12:37 AM
BlackBeauty43's Avatar
BlackBeauty43 is on a distinguished road
Default Low voltage issue from underdrive pulleys, will be taking them off.
I bought an underdrive crank and alternator pulley and had a TERRIBLE voltage issue, my blazer is not a drag car and I need to it for a daily driver, so this simply won't do. The only way to help this issue is to get a smaller alternator pulley, which I had no luck finding one that fits perfectly. A higher output alternator would help the issue as well, which I do not have one.
I can't elaborate on performance gains for one big reason, I had a bad misfiring issue sneak up on me at the same time of installing these pulleys and I am having terrible engine performance because of it. But I hear underdrive pulleys DO work.
In any case, I will be taking the pulleys off, I simply need the electrical demand for daily driving.
If you need your blazer for a daily driver, underdrive pulleys aren't for you.
Hope this helps answer some questions for those of you that are not sure if underdrive pulleys are for you!
Old Aug 22, 2013 | 02:35 AM
Thogert's Avatar
The new member area is for introductions only please.
**Moved to Engine & Transmission**
Connor G. Ivey
Aug 15, 2015 01:13 AM
2001Blue
Dec 31, 2010 12:16 PM
minijosh
May 16, 2007 03:17 PM
RedBlaze
Engine & Internal
Oct 9, 2006 09:45 AM
ivannj
Feb 14, 2006 07:10 AM
