Low1 won't hold my truck back going down hill, why?
Old Jul 17, 2010 | 01:24 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
When i put in Low 1 and gas it, it goes normal. but if i go down hill in Low 1 the truck rolls like as if its in neutral without trying to bring the RPM's up and i hear some rattling,skipping noise, why? the motor used hold me back in low 1 if i didnt give any gas.... also, i dont know if its because the warmer temperature outside but after driving for 20-30 minutes i hear some noise from under the truck and it increases and decreases with RPM....anyone got any ideas on whats going on? my truck is a 4.3 automatic 4x4 with 62k miles on it.......
i forgot to mention that im not giving any gas when im going down hill when it happens....
Last edited by swartlkk; Jul 17, 2010 at 03:22 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
Old Jul 17, 2010 | 03:06 PM
abig84's Avatar
What transfer case and size tires you got? That's weird cause I got 373s and 33s and I go like 3mph down hills with rpms blaring
Old Jul 17, 2010 | 03:21 PM
Sounds like either bad over-run clutches or a broken lugs on the over-run hub in the input sprag.
Old Jul 18, 2010 | 10:28 AM
so that means that i have to pull the tranny out?
Old Jul 18, 2010 | 02:46 PM
You might want to have a trans shop verify first, but yeah.
indec01
Feb 1, 2016 11:04 AM
kruelblazer
Mar 29, 2015 10:02 PM
ABSLT
Aug 31, 2012 11:46 PM
kgkern01
Jun 21, 2011 03:55 PM
oldchevron62
Nov 24, 2006 03:05 AM
