lower end rebuild, need advice
Old Feb 24, 2009 | 09:08 AM
kenny's Avatar
kenny is an unknown quantity at this point
Default lower end rebuild, need advice
Here is my problem 95 jimmy 4.3 w 198,000 on original engine. It just developed a rod knock the other day I dont think I spun a bearing. Anyway did a comp check 166 to 170 on all, so that goes. I need to keep this for another year or so it is my work truck. Should i go for justA lower end rebuild or A new long block block. How long do u think the upper half will hold out? I put 175,000 on this truck and it has been very well mantained.
Old Feb 24, 2009 | 12:19 PM
Default RE: lower end rebuild, need advice
With that good of compression, you should have no problems with the upper end of the motor.
You will still probably want to pull the motor and have the crank mic'd to make sure that you have not scored a journal. You will also want to polish up the crank journals before putting it back in if there is any minor scoring. A new main and rod bearing set and you should be good to go.
dieseltwitch
May 24, 2013 04:43 PM
bobby099
Lowering Tech
Jun 21, 2012 12:15 AM
thercholic
Nov 11, 2010 10:19 PM
nobody500
Lowering Tech
Oct 7, 2009 07:33 PM
88s10Blazer
Dec 25, 2007 09:29 PM
