Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
wanna lower my 98 4x4 blazer 3/4 need some advice
Old Jun 17, 2012 | 06:11 PM
bobby099's Avatar
bobby099 is on a distinguished road
Default wanna lower my 98 4x4 blazer 3/4 need some advice
well i choose to do 3/4 kit because i didnt want it to sit higher in the back ive seen blazers that sit higher in the rear i need mine to sit level but i was telling my friends what im about to do and they said i couldnt do 4 in the back because my rear end will rub the frame. they said 2/3 will be perfect i wanna lay it on the frame but i dont wanna scrap the ground or pot holes so what should i do? now i need to know what to order now i know i need keys new shocks in the front and blocks with u bolts is there anything im leaving out?
i could really use the help thanks.
Old Jun 21, 2012 | 12:15 AM
NewbieT's Avatar
NewbieT is on a distinguished road
You should be able to get the same drop for the front by just cranking the torsion bolts down. I don't think 4in in the rear would cause you to rub, but then again I haven't dropped mine yet You will want to check your pinion angle before and after you put the block's on, they make angled block's for pinion correction.
FireInMe17
Jan 9, 2013 05:15 PM
ohsofly
Apr 19, 2011 09:53 PM
jbentl07
Lowering Tech
May 1, 2010 07:43 PM
97Bravada
Suspension Tech
Mar 20, 2010 10:22 AM
kenny
Feb 24, 2009 12:19 PM
