ls1 or lt1
do you have the motor already?? if not i would start looking around and pricing the motor and all of the items needed for the swap, another thing to think about is are you looking to buy the block and build the motor urself or buying a motor thats ready to go and be bolted in. theres alot of info on this site about the motor swap subject try searching for some just so you can get an idea of how big of an undertaking this is.
You're more than likely going to have to replace the transmission, new gear ratios, several small things that'll add up real quick on top of the cost of a motor. If you're buying a new motor and having someone install it, I think it will cost 5-6k but that depends on several things such as where you get the motor, who installs, the transmission you get, etc.
okvortec-the ls 5.7L will bolt right up to the tranny and as far as the gear ratio's it depends on wat ratio he already has in the blazer i beleive watever stock ratio he has will do just fine the only reason to change the ratio after the swap would be to get an increase in performance/mpg's
We have had the discussion of whether to turbo or drop a v8 in before.
