Manifold Leak
Old Nov 7, 2012 | 03:56 PM
xgiovannix12's Avatar
I wouldn't fix it like that anyways. 1. Its not safe 2. You are already in there so fix it the right way.
Old Nov 11, 2012 | 10:37 PM
CodyL.'s Avatar
CodyL. is on a distinguished road
Thanks yall I really appreciate the suggestions and help, I'm just prolly gonna borrow some money and go get it fixed. I'm not really that mechanically inclined so I don't think I could do anything by myself.
Old Nov 12, 2012 | 12:55 AM
Diaita's Avatar
It's not a tough project. no special tools or procedures. get a haynes or chilton manual to guide you. the gaskets are cheap. set aside 4 or 5 hours(it shouldnt take that long, but if your green...)
Old Nov 23, 2012 | 05:48 PM
USMC3782's Avatar
USMC3782 is on a distinguished road
just did it on my 98. as long as you take pics as you go and label the nuts etc it is easy enough to do. i did pugs wires cap rotor and full intake gasket for under $300 (mind you the plugs alone were $6 each at my cost) the biggest thing is taking out the distributor, just make a mark with whiteout on the dist and intake so they line up right when you put it back in.
Old Nov 24, 2012 | 09:29 AM
Gill747's Avatar
Gill747 has a little shameless behavior in the past
Default Manifold Leak
I was told by my mechanic a while back that I needed a water pump on my 98 Blazer.
I took it in for some other stuff and the water pump.
He told me later that it was not the water pump, but manifold gasket needed to be replaced
~ $ 500.. Well, the leak was small so I bought a little vial of coolant gasket sealer for under $2 from Napa. I have traveled over a 2000 miles and no leakage. I still check the revisor every couple of days and carry coolant.
Richard
sh1520
Oct 29, 2008 06:05 AM
hoffy015
Dec 19, 2007 09:20 AM
pilgrim
Engine & Internal
Nov 14, 2006 02:06 PM
blazerdan
Jul 14, 2005 12:51 AM
00blazer
Mar 30, 2005 12:24 PM
