Manual tranny
Old Jun 16, 2009 | 05:56 PM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default Manual tranny
just blew my 4l60e auto, wanna convert to stick, what trannys can i pair up perfectly to mine, btw my truck is a 97 2 dr 4x2
Old Jun 29, 2009 | 11:43 AM
dahondaboy's Avatar
Banned
dahondaboy is on a distinguished road
i am on the same page. i have a crappy 4l60e and i bought a t-5 manual 5spd. out of a wrecked 98 blazer, i had to get the clutch pedal/master cyl assembely and nutral saftey switch wiring, out of it along with the drive shaft and clutch-pilot bearing.
i saw its a 2-wd you have, i would throw in a th-350 and have a local shop, mate up the drive line for you! im not sure but the important thing is that the input shaft splines match, you will have to find out how many teeth are on your spline and then find a tranny tho match that. the bellhousing is the same on most chev models but the teeth and input shaft length vary
Last edited by swartlkk; Jun 29, 2009 at 07:56 PM. Reason: Combining Consecutive Posts. Please use the EDIT feature to add additional information to your post. Consecutive Posting is prohibitted.
Old Jun 29, 2009 | 07:56 PM
Do not forget the PCM reprogramming so it does not go nuts when it does not see the 4L60E.
K5joker
Oct 18, 2009 06:55 PM
midnightmekanik
Jul 5, 2009 03:33 PM
mmmorris
Jun 8, 2009 11:24 AM
TBIMan
Mar 31, 2009 03:32 PM
oisinirish
Mar 2, 2009 09:32 PM
