K5 Auto to Manual Tranny
Old Mar 2, 2009 | 09:41 AM
oisinirish's Avatar
Default K5 Auto to Manual Tranny
I'm sure this has been discussed before but for the life of me I can't seem to find anywhere.
Which manual transmission is a direct swap for the stock automatic?
Old Mar 2, 2009 | 12:22 PM
Default RE: K5 Auto to Manual Tranny
There is not a whole lot of K5 stuff here yet...
As far as which manual transmission was offered in your year K5, there were actually quite a few. As far as being a direct swap, well...
I believe the most common is the SM465. You will likely need a different adapter for your transfer case and possibly a different input shaft for the t-case as well.
Old Mar 2, 2009 | 01:14 PM
oisinirish's Avatar
My book refers to 3 different manual transmissions
a 3 speed that's all it says.
4 speed 89mm
4 speed 114mm
These numbers of little help. Looked all around. Any clues?
Old Mar 2, 2009 | 02:15 PM
There were quite a few 3 speed transmissions.
Are you sure it says 114MM? I have found some references that state that the SM465 == 117MM.
I only found one reference that said anything about the 89MM and that was only to say that it was a 4spd w/ a 25% OD 4th gear and that it was in late model 1/2-ton Chevy trucks. But that was it.
Old Mar 2, 2009 | 03:43 PM
oisinirish's Avatar
You're right it was 117mm. Where'd you find that?
Old Mar 2, 2009 | 09:32 PM
It was just something that turned up when I did a google search on it. I think it was on the FullSizeChevy.com forum.
goser
Engine & Internal
May 22, 2011 09:05 PM
K5joker
Oct 18, 2009 06:55 PM
94blueknight
Apr 7, 2008 09:54 PM
craig972
Mar 18, 2008 11:48 AM
BlaZeR FXB1581
Engine & Internal
Mar 6, 2006 03:32 AM
