Manual transmission lube
Old Apr 7, 2008 | 08:43 PM
ron768's Avatar
ron768 is an unknown quantity at this point
Default Manual transmission lube
I have a 02 blazer with the 5 speed transmission, the dealer tells me it takes syncromesh lube at 15 dollars a quart. anyone know of a cheaper substitute or where I can get it for less than the dealer sales it for?
Old Apr 7, 2008 | 09:53 PM
Hanr3's Avatar
Default RE: Manual transmission lube
Get what you want, however even @ $15 per quart it is cheaper then rebuilding your tranny due to a failure cuased by a cheaper grade of lubricant. Tranny's are the one part of a truck that take the most abuse and get the least maintenance. spend the money on the good stuff, you;ll be money ahead in the long run.
Old Apr 7, 2008 | 10:27 PM
blazin97's Avatar
blazin97 is on a distinguished road
Go to any parts store and ask them, its about $7 a quart and you need 2.2 quarts if your empty. You MUST use synchromesh.
Old Apr 9, 2008 | 05:10 AM
ron768's Avatar
Thank you. I will have to get the local parts places to order it. None here carry it as there has been no demand for it.
gizwilly
Jan 16, 2007 09:17 AM
USMaverick101
Dec 1, 2006 12:45 AM
Aquahallic
Jul 29, 2006 01:06 AM
Binz316
Apr 12, 2006 12:55 PM
4lowlife
Suspension Tech
Mar 8, 2006 03:53 PM
