Suspension Tech Have a question about modifying your suspension? Ask it here.
Tech: Lube up leaf springs
Old Mar 7, 2006 | 09:01 PM
4lowlife's Avatar
Default Tech: Lube up leaf springs
I jacked the truck up and sprayed lithium grease between the leaf springs. I did a rear brake job and took it out for a ride. I noticed a sqeek it had is now gone. I would recommend any do this if a noise is suspected in the rear.
P.S. Don't mess w/ the parking brake shoe. I tapped it to get some dust off and it dragged on rotor when I drove. P I the A to get it centered. A good hammer will suffice.
Old Mar 8, 2006 | 10:52 AM
DaveLance's Avatar
DaveLance is an unknown quantity at this point
Default RE: Tech: Lube up leaf springs
Excellant post. I saw a similar one on another forum and I plan on doing it this weekend.
Old Mar 8, 2006 | 01:33 PM
The lithium grease may not last all that long. For longer protection, you could try to put on a standard grease between the springs.
I know on several other trucks that I have worked on, there were rubber isolators between the ends of the springs. Kind of sucks that we don't have that option on ours. Makes for a nice quiet ride.
Old Mar 8, 2006 | 01:56 PM
4lowlife's Avatar
(in reply to 4lowlife)
My dad gave me they idea when he was over. And yeah it's been done before.
Probably next time I'm out at the A zone I'll get some. Wonder how high temp anti/never seize would hold up? The best would be liquid graphite. The lithium grease will dry up in the heat eventually. But makes for a quick fix!
I agree. And have greasable shackles like the oearly model Vettes!
*sigh, the good 'ol days.
Old Mar 8, 2006 | 03:53 PM
I don't think that antiseize would work well at all. It is meant to be squeazed into tight areas. It will dry out over time just like lithium grease and will make a mess besides. The best thing to do would probably to put in a thin peice of rubber to isolate the springs, but I'd have to take a closer look to see how to retain the rubber.
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
lennyblazer
Jul 6, 2007 11:10 PM
2Tone
Mar 29, 2007 12:20 AM
alamantia
Suspension Tech
Nov 17, 2006 11:14 AM
tommyd
Suspension Tech
Aug 25, 2006 12:11 AM
