Map Sensor
Old Aug 8, 2007 | 09:01 AM
ggwash21's Avatar
ggwash21 is an unknown quantity at this point
Default Map Sensor
I think i figured it out after readong some more posts. now my questions is if the
MAP sensor is bad will it kick a code or not? If i have it put on the Computer at teh shop will it scan
it as a bad MAP?
thanks
Gary
Old Aug 8, 2007 | 08:58 PM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
Default RE: Map Sensor
yes the MAP sensor should put out a check engine code. One way to check is to clear all codes. Unplug the MAP sensor and start it you should get a code (code 33 for low voltage, or 34 for high voltage, this would be if you have an blazer with OBD1. Im not sure for OBD2 systems) you shouldgetthisa code then clear the code, plug inMAP sensor, and start it, if you get the code again your sensor could be bad. Hope this helps.
jigger
Nov 9, 2009 12:05 AM
Sunshine Coaster
Oct 20, 2007 12:24 AM
01extreme
Jun 10, 2007 07:52 PM
Aquahallic
Aug 19, 2006 11:20 PM
swdockter
Mar 29, 2006 11:41 PM
