miss fire at 50mph
Old Apr 27, 2010 | 09:45 PM
jeffkoski's Avatar
jeffkoski is on a distinguished road
Default miss fire at 50mph
2001 blazer stumbles between 50 to 55 mph no other time plugs are new cap new but it pulls up codes on crank and cam sensors why would they just miss fire at those speeds
Old Apr 28, 2010 | 06:21 AM
Intermittent conditions can be caused by faulty wiring, loose components, etc.
But lets start with the specific codes. Your PCM is trying to tell you what's wrong.
Old Apr 29, 2010 | 09:36 PM
jeffkoski's Avatar
Question cam sensor can be replaced by rookie but the crank needs to be replaced at shop right? replaced plugs thet were gapped at 75 and the one behind steering shaftwas real black
Old Apr 30, 2010 | 06:26 AM
Either may require a CASE relearn (aka. crankshaft variation learn procedure) to properly calibrate the PCM to the variation of the new sensors. Either can physically be replaced in your driveway.
tall_ish
Nov 20, 2010 09:05 PM
iloveblazers
Aug 13, 2010 09:33 PM
scott_wheels
Jan 26, 2010 05:49 PM
Tblazer99
Nov 5, 2007 01:12 PM
grdylan
Jun 5, 2007 05:27 PM
