misserable chevy blazer 2003 4.3 vortex
have a problem getting any power idles perfect 60 lbs at fuel rail replaced
MFA sensor,fuel filter and a new fuel spider assemble and I still get the same thing also is there a way to read codes by the check engine lite don't have money for code reader
Most parts stores can check it for you. If not they usually rent them.
Might be time for a new cat, though get the code(s) read first.
mass air flow sensor
try unplugging your mass air flow sensor - the engine will kick into a default mode without the sensor and if it runs better without it then have yours tested.
worked like a charm for me - mine had no power above 45 mph, valves rattleing at 3500 rpms, transmission acted like it was shot - wouldn't downshift right.
mafs
I all ready put a new one in iam thinking its the catalic converter
Blazthis
06-01-2009 07:59 AM
chopsling
11-17-2008 01:26 PM
jes9999
03-12-2006 01:40 AM
