1994 blazer tahoe 4.3 vortex w series
Old Jan 21, 2008 | 12:34 PM
redneck's Avatar
redneck is an unknown quantity at this point
Default 1994 blazer tahoe 4.3 vortex w series
I have no power once ir warms up it keeps boggin out then it takes a few min before it restarts
I have replaced the injectors the spider tps iac plugs cap rotor fuel pump computer and prom
egr map fuel filter firing order is right I replaced the distributor also cn anyone tell me what I can do now to get this thing to run right
Old Jan 21, 2008 | 02:23 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Default RE: 1994 blazer tahoe 4.3 vortex w series
Have you checked the catalytic converter?
SES light on?
Old Jan 21, 2008 | 11:56 PM
Chevy Lover's Avatar
I'm thinking possible plugged exhaust. Try pulling out the O2 sensor and running it.(to test)
Old Jan 22, 2008 | 02:39 AM
thegr81's Avatar
ORIGINAL: Chevy Lover
Would be the faster way to test for a plugged exhaust, and also the cheapest!!
Old Jan 22, 2008 | 12:48 PM
redneck's Avatar
converter is good o2 senseor is brand new
Old Jan 22, 2008 | 02:46 PM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
have you check for compression? in all cylinders.
you said you replaced yourfuel pump did you make sure fuel pressure is around 50psi-60psi running/off? maybe falty pump.
any check engine lights? codes? is the timming correct?
good luck
Old Jan 22, 2008 | 03:23 PM
rriddle3's Avatar
This just sounds like a typlical ICM failure to me. Check this thread and see if you get the same impression.
atvwarrior
Nov 6, 2016 02:15 PM
atokad55
Engine & Internal
May 23, 2011 01:31 PM
jeffy
Dec 14, 2008 01:11 PM
BIG4EVER
20
Sep 20, 2008 02:45 PM
SniperX13
Jun 18, 2006 12:38 AM
