Missing like crazy
Old Apr 3, 2007 | 09:33 PM
Chevyguy032's Avatar
Chevyguy032 is an unknown quantity at this point
Default Missing like crazy
Well today I am driving home from work...its runs fine...and out of no where when i start goin from this light it misses when you get high in the RPM's...It did this before every now and then...so does anyone know what could cause this?? cause now it happens in the low RPM's to..thanks
Old Apr 3, 2007 | 11:49 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Missing like crazy
I think you stated in your last post that you already tuned it up. So I would pull the capand rotor off, and look real close to the magnet on the rotor shaft. Around where the rivits are the magnet likes to crack. Also I would check all of the grounds, paying specialattention to the ones on the t-stat housing, and behind theheads.
Old Apr 6, 2007 | 11:04 AM
kerander's Avatar
kerander is an unknown quantity at this point
Ignition coil perhaps?
4x4Sandman
17
Apr 23, 2018 03:23 AM
mdabbs
Jul 15, 2015 08:19 PM
dannp73
May 5, 2010 10:12 AM
mudd
May 14, 2008 12:02 AM
