Motor swap
Old Mar 30, 2008 | 09:33 PM
im2ys4it's Avatar
im2ys4it is an unknown quantity at this point
Default Motor swap
If I were to change out my 4.3 vortec in my 95 S10 blazer what yr motors could I use other than that yr?
Old Mar 30, 2008 | 09:38 PM
WolfPack's Avatar
Default RE: Motor swap
95...tricky computer system. It'd probably be safest to just stick with another 95 unless you find out if you're truely OBD1 or OBD2. If you've got that nasty oBD1.5, that's when I would think you need to stay with 95.
Feel free to correct me.
Old Mar 30, 2008 | 10:23 PM
blazin97's Avatar
blazin97 is on a distinguished road
carb'd 350 like my brother is doing(95_4door)
Old Mar 31, 2008 | 08:39 PM
Hanr3's Avatar
You should be fine with a pre '95 engine provided you swap the intake and all teh engine sensors over to the donor. '96 and later the intake ot head bolts are different angles. '92 and prior did not have a internal balance shaft. I think your best bet is a '93 to '95. Remember these engines lived in all sorts of GM vehicles. Fullsize trucks, Astro vans, etc. Your not limited to just Bravadas or Blazers.
LesMyer
38
Jan 9, 2020 11:45 AM
rob1621
Feb 29, 2008 08:15 PM
mmench
Aug 15, 2007 01:39 PM
Netguru24
Aug 6, 2006 02:12 AM
