Multiple codes P0300, 0131,01710,1133
Old Oct 12, 2018 | 03:33 PM
dcimike125's Avatar
dcimike125 is on a distinguished road
Default Multiple codes P0300, 0131,01710,1133
Back in May, I replaced the Cat and all 3 O2 sensors in my 2003 4.3. Now I keep throwing random misfire and O2 sensor 1 codes (P0300, P0131,P01710,& P1133). I also replaced the vacuum line from the intake to the HVAC. I do have good vacuum now. Any ideas?
Old Oct 12, 2018 | 09:02 PM
2001ZR2's Avatar
is the third code P0171?
P0300 is random misfire as you have identified
P0131 O2 sensor low voltage bank 1 sensor 1
P0171 System too lean bank 1
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
From that I would guess you have bad wire or bad O2 sensor on Bank1 sensor 1 which would give some misfire. I forget which one that is but here on the board the information is available.
Did you use Bosch O2 sensors? Some people had reported issues so I would recommendan ACDelco or Denso.
Old Oct 13, 2018 | 09:51 AM
dcimike125's Avatar
they are Denso and I've already replaced that one once. I guess its a bad wire
Mitsuman
Jan 25, 2018 09:06 PM
JetJock79
Mar 7, 2011 10:32 AM
arbie104
Dec 30, 2010 08:22 AM
atwistd1
Engine & Internal
15
Jul 28, 2006 08:46 PM
cjklatt
Apr 3, 2005 02:00 PM
