My coolant temp sensor was giving me the business
Old Dec 10, 2011 | 11:37 AM
Blazeredtodeath's Avatar
Blazeredtodeath is on a distinguished road
Default My coolant temp sensor was giving me the business
This is my first post. Please for the love of all that is Holy, don't torch me. I'm a long time lurker and this forum has saved me time and helped me with all of my trouble shooting. I feel it is my duty to post the following:
I am the recent owner of a new-to-me 2000 Chevrolet Blazer ZR-2. I have had some major issues with this truck. Again, this forum coming to my rescue more times than not. When I bought it, I had never owned a vehicle with the sawed off 350, so this has been quite an adventure.
As of this posting, I have replaced the following parts:
Battery
Fuel injector spider
Idle Air Control Valve
Throttle Position Sensor
air filter
Cap, plugs, wires and the distributor module (I don't remember the exact name)
MAP Sensor
brakes (not related)
cleaned my TB, MAF and upper plenum
change oil every 3K miles
All of these things combined did not solve a stuttering problem and high/hanging idle problem that has plagued me for weeks, and made the truck undriveable. I also didn't find anything like this on the forum, although I could have missed it with all of my vehicle induced stress. I was fed up with parts swaping/trouble shooting. I took it to a mechanic who has a reputation for solving the hard to find Gremlins that no one else can.
So, I drop the truck off yesterday. I leave, and before I am 15 minutes down the road, he calls and tells me that my problem is my coolant temp sensor. I say, "Well, don't I feel like an idiot. I'll be right there."
He charged me $65.00 to run the computer diagnostics and test drive, but in retrospect, it was well worth it. I asked why the coolant temp sensor had anything to do with my idle and whatnot and he told me that due to the motor not having a traditional choke, the computer relies on the coolant temp sensor for a baseline to do air and fuel mixture and metering. Therefore, when my sensor was reading -40 degrees fahrenheit, when it was actually 75+ outside, it was dumping excessive fuel and couldn't get enough air, causing the stuttering.
I apologise for the long winded nature of my first posting, but I wanted everyone to learn from my automotive beat down. This could have been a whole host of things that cost a couple hundred to fix, but instead I got owned by a $14.00 temp sensor. Ten minutes worth of work and my truck runs like a top.
I hope you all have a Merry Christmas and happy Blazering.
Sincerely,
Blazeredtodeath
Old Dec 10, 2011 | 11:47 AM
chris015's Avatar
Glad you got it fixed. Those temp sensors really get pushed to side alot of times...and if i recall mine cost me 13 bucks..Whenever i buy me "new" gm's,or anything for that matter i buy plugs,wires,etc and i also throw in a new temp sensor as they are a important cheap part of the fuel system. Remember you have 2 of them,ones for the fuel etc,ones for the gauge
Old Dec 10, 2011 | 11:52 AM
Where is the second temp sensor for the fuel located? I am in the pre-emptive strike mode. I'm tired of getting left on the side of the road. Chevy runs deep...in my wallet.
Old Dec 10, 2011 | 12:10 PM
chris015's Avatar
the one for the fuel is under the throttle body.takes like 5 minutes to change out. on the cpi's i believe the one for the gauge is still on the passenger side head.
Old Dec 10, 2011 | 12:58 PM
pettyfog's Avatar
I dont understand the question.. there's a fuel temp sensor?
Now I REALLY dont understand the question. "Under the throttle body?" What!
BTD: The guy probably got in the truck you had just driven in and saw the temp was low.
If the thing's a 2000, the PCM drives the gauge.
Problem being I have a harness pictorial that shows the ECT on the driver's side head. I trust the schematic and there's ONE!
Old Jun 1, 2020 | 02:16 PM
tslyks's Avatar
tslyks is on a distinguished road
Hi guys,
I know this is a real old post but I think I may have the same problem.
My question is: will a vehicle run fine when it's cold but stall out and won't start up again once it warms? My vehicle died on me on the hwy when I was at red light. I couldn't accelerate and I had just enough juice to pull over before she puttered out on me.
I made post just the other day about my issue.
https://blazerforum.com/forum/2nd-ge...n-cold-101748/
Old Jun 2, 2020 | 06:46 AM
Thread closed. Not bumping old threads. User has opened a new thread.
zakm0n
Jan 9, 2011 07:31 PM
bwrobo
Sep 13, 2010 12:26 PM
dutchs98blazermarkIII
Apr 5, 2010 06:30 PM
MrRox
13
Dec 31, 2009 09:06 AM
mbnorton
Oct 17, 2006 11:24 PM
