My ecm wires burned up
I need help my ecm wires burned up I think it’s from the exhaust tube the 90 fitting rotted thru and most of my wires burned out and I need to confirm if anyone had this problem
The vacuum hose from the solenoid also burned thru
OH DAMN
in my build thread i posted a long holy-hell-replace-your-valves rant when that happened to me while flying down back roads lol.
i had my machinist make blockoff plates, install new studs and nuts when you do replace them. removing that system will not do anything unless you are in california or a state with emissions inspections yearly. check with local laws.
I can pull the PCM Diagram possibly, give me a little bit to find it.
i cant seem to find the copy i had on hand, so best bet would be to de-loom the harness, and match your wires, chances are they are still connected just melty so physically trace each one back to where it goes and match color/stripes along the way, and seriously consider doing an A.I.R Delete.
pjdupont1
03-06-2022 11:13 PM
