Need 2001 4.3 ECM Pinout Diagram
Old Jan 25, 2018 | 09:41 PM
FLHTK's Avatar
FLHTK is on a distinguished road
Default Need 2001 4.3 ECM Pinout Diagram
I am working on an Arduino remote starter project for my 2001 Blazer 4.3 4x4
For safety reasons I need to check the status of several things: door lock position, ignition key in or out, park/neutral position, engine RPM, & vehicle speed. I am assuming that I can read each of these from the E.C.M. but I need a Pinout or diagram to indicate the proper wires to check.
Does anyone have a PDF copy of the '01 Pinout or other document that would help me?
Old Jan 26, 2018 | 07:37 AM
Transman304's Avatar
Give me vehicle specs and I will look them up and send them to you. I need make, model
You gave the year and engine size. Also 4x4 or AWD.
Old Jan 26, 2018 | 06:31 PM
FLHTK's Avatar
Default I guess I left out Chevy
2001 Chevy Blazer LT 4.3L 4x4
Old Jan 26, 2018 | 08:03 PM
Here is the body computer, starting and charging diagrams. Let me know if you need something else.
Old Jan 27, 2018 | 09:33 PM
FLHTK's Avatar
Thanks a bunch. Looks like just what I needed.
Old Jan 28, 2018 | 05:11 AM
No problem at all. Glad to help.
Old Feb 18, 2019 | 04:07 PM
Chef_Robert's Avatar
Chef_Robert is on a distinguished road
Default Bbbh
2001 GMC Jimmy four-door , 4WD 4.3L 4 Wheel Dr. car controls on the dash through the vacuum system
vin
1GKDT13W412168829
Robert Hyttenhove
Chef_Robert name
904-436-8215
Old Feb 18, 2019 | 04:13 PM
Default Engine control module under the hood passenger side
I require the Engine control module on top of the fender well in the engine compartment on the right hand side passenger side wiring diagram with pin numbers
Old Feb 18, 2019 | 05:09 PM
2001 GMC Jimmy four-wheel-drive four-door AWD
Old Feb 19, 2019 | 09:57 AM
LesMyer's Avatar
"I require" is not a good way to ask for help, and in another person's thread. AlldataDIY.com will have the wiring diagrams that you need. Jimmy might be different in the specific area of your interest, whatever that is. also could be exactly the same.
