Need 2001 4.3 ECM Pinout Diagram
Old Feb 19, 2019 | 02:21 PM
Chef_Robert's Avatar
Chef_Robert is on a distinguished road
Originally Posted by LesMyer
"I require" is not a good way to ask for help, and in another person's thread. AlldataDIY.com will have the wiring diagrams that you need. Jimmy might be different in the specific area of your interest, whatever that is. also could be exactly the same.
I guess I should’ve said if you have time could you assist me sorry
Old Feb 19, 2019 | 02:24 PM
Default I’ve never used forms And threads
Originally Posted by Chef_Robert
2001 GMC Jimmy four-door , 4WD 4.3L 4 Wheel Dr. car controls on the dash through the vacuum system
vin
1GKDT13W412168829
Robert Hyttenhove
Chef_Robert name
904-436-8215
I have never used forms and threaSS I didn’t know I broke into someone else’s thread I have no idea how to set up my own thread with Transman304
Old Feb 19, 2019 | 07:21 PM
Transman304's Avatar
Maybe this will help.
Old Sep 19, 2019 | 12:49 PM
Cruz Angel's Avatar
Cruz Angel is on a distinguished road
I'm in the almost same issue can you help me out need color oinout from ECM to ignition swith
Thanks
Old Sep 20, 2019 | 12:07 PM
Cruz Angel's Avatar
I'm having trouble with a against the PCM trying to figure it out it won't start cranks but no start.Can you help me out
Old Sep 20, 2019 | 02:25 PM
LesMyer's Avatar
What year Blazer? Do you have spark at the coil (hook up a plug wire directly with a grounded spark plug)? If so, do you have fuel pressure when turning the key on (correct amount ~ 55psi+, without engine running) and are the injectors being driven (use a noid light at the injector connector). Answer these things and we can go in the right direction to get it running.
Old Dec 5, 2020 | 03:11 AM
Josh Dow's Avatar
Josh Dow is on a distinguished road
[QUOTE=Cruz Angel;713664]I'm having trouble with a against the PCM trying to figure it out it won't start cranks but no start.Can you help me out[/QUOTeHey I understand this is an old post
But it sounds like I'm having the same problem you are my truck cranks but it won't start the it displays it's in reverse after fighting I finally discovered it was really in reverse when I find out the truck and push the transmission into Park. If you can let me know what's your problem ending up being I'll be very grateful save me a big pain in the A**
959900s10blazer
Nov 1, 2020 10:25 PM
mmmrodge
Apr 20, 2015 12:52 PM
Dave884x4
May 14, 2013 09:14 AM
Xb-lineblazerX
Jul 9, 2012 09:04 PM
95chevrolets10blazer
Oct 24, 2011 01:42 PM
