need a 4.3 aluminum block
does anyone know where I can find an aluminum 4.3l block at? I need to rebuild my motor and the one I have is shot. any help would be great. thanks
RE: need a 4.3 aluminum block
um... GM 4.3L aluminum block...??? They are cast iron.
not all of them are cast iron. I have an aluminum one right now but need one to rebuild one
Well then... What do you drive? Year? I'm very curious as to how you got an all aluminum 4.3L block...
The article linked to below is pretty much the resource for rebuilding the 262. No mention of an aluminum block...
Rebuilding the New Chevy 262 by Doug Anderson
I'm not trying to be difficult, just trying to determine what it is that you have. The 4.3L v6 was only offered in a cast iron block from the factory.
Yep chevy never put an aluminum 4.3 block in any s-series trucks. If you say yours is aluminum either its aftermarket or possibly a marine engine( don't even know if those were aluminum)
Just so everyone here knows, I never said anything about what it came in or that it was stock in something, all I did was ask if anyone knew where I could get one. The motor I have is in an off-road car (nothing stock). I got the first motor from a builder in Las Vegas but he gave me crap parts on the block waas hurt so I need a new or used block in good condition so I may rebuild it with someone else. I know of 2 places to get one but the price seems to me to be a bit on the steep side. Sorry if I made any confusion for anyone.
http://www.hotrod.com/pitstop/hrdp_0...nce/index.html
Here is something that talks about it so you guys can see for yourself
What kind of block is it? V6 or V8? Longitudinal or Transverse mount? You aren't giving us any real information to go on here... Only information is that it is a 4.3L and that it is an aluminum block. Not sure what else to say...
*EDIT* - More questions... Is this motor based off of the GM Vortec 4.3L or is it based off of the Buick 3.8L? If based off of the 3.8L, TA Performance has an all aluminum v6 block capable of being punched out to 271CID (4.3L = 262CID). Down side is the bare block is $3900 from the cataloge page I found...
GM 4.3 marine was an aluminum block, never made it in any production trucks but it can fit with some mods. They are pricey.
Theres even some gen1 RWD 2.8 and 2.5 AL blocks floating around.
ORIGINAL: dirtdriver85
PACE Performance carries it for just a tick under $4k... Man, for that kind of dough, I would put the money towards building a more powerful cast iron block to make up for the added weight (probably over double the weight for a cast iron block - 150-200lbs). But you didn't ask about that...
*EDIT* - The aluminum block is ~80lbs while the cast iron block is ~165lbs. Is 85lbs weight savings worth the additional $$$? 25534333 ($1800-$2000) is for the cast iron block with nodular iron caps and grade 8 hardware.
Man 350horse from a mild build on a 4.3L, add in a power booster to hit 500 horses. Too cool.
Talk about a screamer.
I got a spare block sitting in the garage some guy I used to work with gave to me. How could I tell if it was an aluminum block? I know its shiny and no rust on it.
