Need help accessing slave cylinder bleeder valve
Old Aug 1, 2017 | 06:39 PM
Turbo1's Avatar
Turbo1 is on a distinguished road
Default Need help accessing slave cylinder bleeder valve
Hey guys I have a 98 2 door blazer with a 5 speed nv3500
I can't access the slave cylinder bleeder valve. Any tips? I want to flush my clutch fluid.
Attached Thumbnails Need help accessing slave cylinder bleeder valve-img_6336.jpg
Old Aug 1, 2017 | 09:34 PM
Rusty Nuts's Avatar
That steel braided line is not from the factory and it looks new. The best tip I can offer is not to worry about it. All my manual transmissions only got new clutch fluid when the clutch was replaced. Unless the bottom of the reservoir looked like the last sip of a cup of hot chocolate. If you're really worried about it, remove some with a turkey baster and top it off with new a couple times. Since your line is flexible can you remove the slave, gravity bleed it and reinstall?
Old Aug 2, 2017 | 09:47 AM
Turbo1's Avatar
The previous owner had the clutch replaced in 2011. Clutch fluid doesn't look too bad. It's black. But liquidy and not thick. I ended up sucking some out with a turkey baster and topping it off with new fluid
To remove the slave won't I have to dismount the transmission ?
Old Aug 2, 2017 | 10:02 AM
Rusty Nuts's Avatar
Yes, the transmission needs to be dropped. I had a flashback to my 91 5 speed which had an older design slave that bolts to the outside.
ChromeJerome
Aug 30, 2023 08:49 PM
Asuryan9
Oct 23, 2012 11:16 AM
Mikeinnh
May 26, 2011 05:59 AM
twintrades
Engine & Internal
Feb 13, 2007 05:29 PM
rooster
Nov 15, 2006 09:27 PM
