Need Help With Engine Casting Numbers
Old Oct 26, 2015 | 08:20 PM
Clark Kent's Avatar
Clark Kent is on a distinguished road
Default Need Help With Engine Casting Numbers
I have a 10410207 small block chevy crate engine in my '86 K5. I had the timing cover off and found "207", "201", "G11", and "X" cast in the block. A picture is attached. I have not had any luck decoding these castings. I already have the info on the 10410207 block but would appreciate knowing what the other codes mean. Anybody out there have a clue?
Attached Thumbnails Need Help With Engine Casting Numbers-cam-timing-gear-removed-1-.jpg
Old Oct 27, 2015 | 01:08 PM
abig84's Avatar
there should be a casting number right in front of where the alternator should be, or in front of the passenger side head facing upwards, should be a bunch of numbers followed by like 3 letters.
How to decode Chevy Engine Codes that site should tell you what it came out of
theres also another set of numbers back kinda by the distributor hole that tells you the date and plant it came from i think, been a while since i bothered with those
89Jimmy4x4
Jan 29, 2014 01:57 PM
beatinPearls
Mar 12, 2010 09:38 AM
PROJECT85K5
Dec 6, 2009 10:55 PM
joedonack71
Feb 8, 2009 01:17 PM
2drblazer
Jun 29, 2008 02:04 AM
