need help fast
Old Mar 19, 2008 | 10:55 AM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
Default need help fast
i hav repaired oil pump on my 91 4.3 4dr blaze ive got oil leaks there are new gaskets on oil pan and valve covers and rear main but today i noticed and small oil leak coming from behind the harmonic balencer is this an hard repair and can any one walk me through it ? please help i want to drive my baby again like i used to oh and it has 138,000 miles on it
Old Mar 19, 2008 | 11:04 AM
Default RE: need help fast
To replace the front lip seal, you need to first remove the accessory drive belt(s). Then remove the crank pulley (3 bolts IIRC - if equiped) and the harmonic balancer retaining bolt/washer.
Next, install a puller to remove the harmonic balancer. A low profile puller may be necessary. I made one out of plate steel with 3 holes to match those in the balancer (used for the pulley) and a larger hole in the center with a nut welded to it. Thread a bolt through the welded on nut and walk the balancer off.
You will then need to pry the old lip seal out of the timing cover, and press in a new seal. Pressing in the new seal can be a challenge with the timing cover still on the front of the motor...
Old Mar 20, 2008 | 09:40 AM
thanks for the help i might just need to let my dad do this one cause i dont want to f it up or anything because i never to do this to any of my other cars i own
88s10Blazer
Jan 22, 2010 01:07 PM
PaulO2288
Headers, Intake, & Exhaust
17
Jan 20, 2010 01:39 PM
nonblazing4x4
Dec 11, 2009 06:47 PM
chris12001
Apr 5, 2009 01:46 PM
RolingKCBlazer
Sep 3, 2008 08:34 PM
