Need Help Guys
Old Feb 16, 2009 | 04:20 PM
newguy07's Avatar
newguy07 is an unknown quantity at this point
Default Need Help Guys
Hey guys,
I have a problem, my wifes 1995 Chevrolet S10 Blazer started sputtering at idle and dying if you turned left or right. Thinking it was a spark issue I replaced the spark plugs, plug wires, dist. cap, rotor, and fuel filter. I took the EGR valve off and cleaned it out real good but its still acting the same.
Some guys have said it may be a vacuum problem and the only vacuum hose that I can find that is not connected is pictured below, do any of you know where it goes?
or do you have any idea of what it could be?
http://img18.imageshack.us/my.php?image=cimg8357up8.jpg
http://img17.imageshack.us/my.php?image=cimg8358wj1.jpg
http://img23.imageshack.us/my.php?image=cimg8359bz5.jpg
Old Feb 16, 2009 | 05:08 PM
oisinirish's Avatar
Default RE: Need Help Guys
Looks to me like it has a check valve on it. Not sure on the S-10's but check under the hood and see if there is a diagram for the routing. On my '86 it's a label right next to belt routing diagram.
Old Feb 16, 2009 | 05:23 PM
newguy07's Avatar
I just got back from the shop and it only threw one code..........................................P140 6
Old Feb 16, 2009 | 08:06 PM
rriddle3's Avatar
IIRC, P1406 is an EGR code. You might try removing and cleaning it.
Old Feb 16, 2009 | 08:12 PM
Please keep things together here.. Double posting is prohibited by the rules of the forum.
Old Feb 16, 2009 | 08:15 PM
newguy07's Avatar
I did not mean to double post, when I figured out what the code was I thought that was a different matter since I still need to know where that vacuum line goes?
rriddle3's Avatar
Yep, just now caught that, too. Since it is already under discussion, there's no need for this thread.
*THREAD LOCKED*
Old Feb 19, 2009 | 07:41 PM
newguy07's Avatar
can anyone help?
Old Feb 20, 2009 | 12:35 AM
Blazercrazy's Avatar
Blazercrazy is an unknown quantity at this point
Is it running lower RPM then normal?..Turning adds drag to your engine from the power steering so it might be dirty injectors or however they build those CPI's lol
Old Feb 20, 2009 | 04:53 AM
newguy07's Avatar
it is running right around 1000 rpms idle which is pretty usual for it
