Need info fast
Old Jan 28, 2013 | 01:18 PM
jimmyttop's Avatar
jimmyttop is on a distinguished road
Default Need info fast
Hi new to this sight and looking for help on this issue I just change fuel pump and got the 95 jimmy sl 4.3 running now when I go to back up it seems like it wont go then it will only if I put the gas peddle to the floor OR after driving it for a a while it seems to work fine Please any help or what I can look at to solve issue Thanks.
Old Jan 28, 2013 | 01:19 PM
newguy's Avatar
Take the ebrake off
Old Jan 28, 2013 | 02:04 PM
neo71665's Avatar
When was the fuel filter last changed?
Old Jan 28, 2013 | 02:17 PM
jimmyttop's Avatar
Hi there ty for the reply the filter was change about three month ago if your refuring to the fuel filter the tranny filter was done around the same time not sure what other fluid I can check tranny fluid is on the marks oil is on the marks as well I just took the wife to work and it worked fine BUT!!!! before I could barly back it out on the driveway after getting home I and no problem backing out GRRRRRRRR whats up with that thanks.Ps forgot to mention theres no fluids leaking anywhere as I would see it in the snow and don't see any heeeeeeeeeeeeeeeelp lol
Old Jan 28, 2013 | 04:41 PM
neo71665's Avatar
Runs fine cold then acts up when at temp classic signs of an ignition module.
Changing out a fuel pump can stir the crap in the bottom of the tank up. Even if it was swapped a few months ago I'd suggest changing it, also swap in after a few tanks of gas.
Old Jan 28, 2013 | 05:02 PM
4x4 canuk's Avatar
4x4 canuk is on a distinguished road
try lifting the back up and rotating the tire by hand. ive had drum brakes lock in reverse only on me.
88s10Blazer
Jan 22, 2010 01:07 PM
PaulO2288
Headers, Intake, & Exhaust
17
Jan 20, 2010 01:39 PM
nonblazing4x4
Dec 11, 2009 06:47 PM
butters
Tires and Wheels
Jul 26, 2008 07:11 PM
strong blazer
Mar 20, 2008 09:40 AM
