need starter help before I crazy!!!
Old Jul 8, 2013 | 10:39 AM
lityjohn701's Avatar
lityjohn701 is on a distinguished road
Default need starter help before I crazy!!!
I have a 98 blazer. my starter hasnt worked right since I swapped the motor out of a 98 s10 2wd. the problem is the starter bendix will kick out and hit the flywheel but wont turn over. sometimes I get lucky and it does srtat. the starter tesred good at autozone. just to clear thisnggs up its not the clicking coming from the fuses under the hood. I have tryed shimming the starter with the universal kit started off with the smallest one and worked up the the biggest and now all three shims are on it and it still does this sombody please help I dont even like drive it to town because if it just clicks I have to pop the hoood and turn the motor over manually then try to start it and hope the staeter is lined up
Old Jul 8, 2013 | 10:52 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
You shouldnt need shims except in rare cases,Check your teeth on the flywheel and make sure they match and mesh in with the tetth on the starter.Also does your engine use the small or larger starter that maybe whats causing your problems.
Old Jul 8, 2013 | 02:08 PM
the starter on mine is small but im not sure if its the snall of big one.we bought tge blazer with a blown motor. we used the starter off the blown motorr on the new one.Not sure if there is a difference
Old Jul 8, 2013 | 02:52 PM
would internal or external thru bolts tell me anything?
Old Jul 10, 2013 | 02:59 PM
The starter should be the small one,Too me it seems like a flywheel problem,have you switched them?Even though the starter may test good the test only checks the motor itself not the bendix.Its possible its not extending all the way out.There should only be 2 external bolts holding it to the engine block.Also look at the wear pattern on the starters teeth they may be worn enough that they are not meshing into the flywheel.
Old Jul 10, 2013 | 09:11 PM
I'm just goinging to buy a new starter and see how that works
jdmmario
Oct 25, 2014 06:25 PM
ccw1911
Jul 20, 2014 03:33 PM
ExplicitYourSelf
Jun 5, 2009 08:40 PM
stevenphillips99
Jan 25, 2009 02:14 PM
