New distributor crank no start 1994 Chevy s10 4.3 v6 tbi hei vin z
Old Dec 3, 2023 | 08:41 AM
Kennethinman's Avatar
Kennethinman is on a distinguished road
Default New distributor crank no start 1994 Chevy s10 4.3 v6 tbi hei vin z
I replaced all plugs wires engine coolant temp sensor cleaned out the fuel pump housing I put a new pump in about 2k miles ago and new distributor cause my old one went out I’ve taken the valve cover off cause I can’t fit my finger over the cylinder hole so I can see if both the valves are closed which means it’s on compression stroke I believe and I turned it from turning the alternator and giving the belt a little tug till the timing mark lined up with 0 on the harmonic balancer I put a screwdriver in the cylinder to see if it was really and it was but I saw videos saying line it up with the engraved notch on the balancer not the first timing mark but the second I read but the second isn’t tdc but I’ve dropped this thing in and out so many times can anyone point me in the right direction?
Old Dec 3, 2023 | 01:41 PM
GeorgeLG's Avatar
It is common for the harmonic balancer to slip position as the truck gets older so that check becomes less reliable.
George
ChevyBoy1984
May 12, 2021 04:13 AM
2bejustme
Jan 27, 2013 05:54 AM
ryderhard
Apr 16, 2012 04:00 PM
recian
Sep 19, 2011 07:56 PM
Camarobird91
Jul 12, 2010 08:30 PM
