New to S-10
Old May 26, 2015 | 12:56 AM
tlamana's Avatar
tlamana is on a distinguished road
Default New to S-10
Issue is that it revs higher then normal but transmission appears to work just fine. No hard 3-4 shift most times. Seems a bit gutless. All fuses appear good. CEL comes on and off (haven't checked codes).
When I got the truck it was low on trans fluid so topped it off. Stunk for a bit like it deglazed the clutches (it was about 5 qts low).
I am not sure where to go first. I had a similar sluggishness on a Crown Vic and that turned out to be clogged cat.
The person I got the truck from said it was a rebuilt engine and trans.
2000jimmbo4x4
Aug 23, 2010 07:10 AM
yazan84
Dec 30, 2007 11:19 PM
thegr81
Oct 19, 2007 08:18 PM
