No 2nd gear
Old Jan 31, 2013 | 04:26 PM
Adamhon11's Avatar
Adamhon11 is on a distinguished road
Default No 2nd gear
My 1999 4X4 blazer has no 2nd gear, all my other gears work fine. I just have to speed up in 1st gear to about 2800 rpm, let off the gas and then it will shift into 3rd. 4th and Reverse work fine, 2nd is the only gear I have a problem with. The tranny shop says I need a rebuild costing $110-1300, I am just wondering if there is anything else it might be, I have tried looking all over the web and I was wondering if maybe it could be the servo?
Old Feb 1, 2013 | 03:17 PM
Adamhon11's Avatar
Any ideas?
Old Feb 5, 2013 | 11:32 AM
Adamhon11's Avatar
Nobody has any ideas?
Old Feb 15, 2013 | 11:10 AM
Adamhon11's Avatar
Took the blazer by 2 tranny shops, first one just said I need a rebuild, second shop took it for a drive with me in it and explained everything. He confirmed that it is skipping second gear totally and said it might be acting a little funny going into 4th(not dropping rpm much right away). He said I should try changing the servo and check the accumulator springs, if that doesn't fix it they would have to get in the tranny. I guess I will try that and see what happens
fiszot
Nov 10, 2008 06:03 PM
pulsarbird
Feb 5, 2007 10:40 AM
94s10Blaze
Engine & Internal
Sep 27, 2006 01:55 AM
blazin97
Jul 29, 2006 06:36 PM
strongboy2005
Feb 16, 2006 06:54 PM
