No fuel after changing cap and rotor
Old Aug 13, 2024 | 06:54 PM
JK72VC's Avatar
JK72VC is on a distinguished road
Default No fuel after changing cap and rotor
Hello,
After work today I went to start my car. It briefly started but did not get above 1000rpms. It sputtered and died. I tried a few more times and this occurred until it simply did not show any rpm’s. Took the cap off and saw the terminal on top of the rotor was broken. Got a new cap and rotor and have spark at the plugs. No fuel though. Do you think this is a bad fuel pump or something else electrical with both issues occurring at the same time without showing any signs previously. Also to mention I checked for fuel at the filter on the frame rail and nothing came out when cranking.
Old Aug 14, 2024 | 09:43 AM
GeorgeLG's Avatar
Year and model?
Do you get 12v at the FP priming tab for 2 seconds at key on?
George
Old Aug 14, 2024 | 10:32 AM
JK72VC's Avatar
Originally Posted by GeorgeLG
Year and model?
George
2003 Blazer ls 4.3L 5-speed 4wd
I didn’t have a test light with me but have one now and will check later. Is the FP priming tab on the relay or fuse? I checked the fuse and relay and they were both fine
Old Aug 14, 2024 | 10:50 AM
GeorgeLG's Avatar
It's in the UHFB usually near the relay.
This is not your year but it will give you an idea:
George
Old Aug 15, 2024 | 05:28 PM
JK72VC's Avatar
Went back to the car yesterday, hopped in, turned the key and started up without hesitation. I’m not really sure what the problem was but I replaced the fuel pump just to be safe. The original pump was still in there and figured it would be best to change it out. Thank you for your help. Even still, do you know why it would just start working again? I could hear the pump turn on like usual this time. Could that just be the motor in the pump going bad?
Old Aug 16, 2024 | 02:25 PM
GeorgeLG's Avatar
Yes a failing pump can become intermittent but there are many other possibilities. When you have intermitent problems, travel with your test equipment so that you can start narrowing down each time it fails.
George
jimdian
Mar 21, 2017 08:41 AM
AutomagicLS1
Feb 14, 2012 03:43 PM
jhemsone
Apr 12, 2010 12:24 AM
ndekens
Apr 4, 2009 03:50 PM
tidoux01
Mar 5, 2007 07:07 PM
