No Oil Pressure Reading
Old Jan 24, 2017 | 11:02 PM
TRANCE101's Avatar
TRANCE101 is on a distinguished road
Question No Oil Pressure Reading
is the oil pressure sensor bad when its not giving any oil pressure in the gauges
Old Jan 26, 2017 | 08:51 AM
LesMyer's Avatar
Maybe, maybe not! What if you don't really have any oil pressure. Check with a test gauge.
Old Jan 26, 2017 | 08:59 PM
TRANCE101's Avatar
OK we change the oil pressure sensor and still the same
so im gonna see if my oil gauge is bad
Old Jan 26, 2017 | 10:03 PM
LesMyer's Avatar
Either test it with a real gauge or you might as well put a brick on the accelerator pedal and walk away.
Old Jan 29, 2017 | 12:29 AM
TRANCE101's Avatar
can it be the gauge that doesnt work
Old Jan 29, 2017 | 04:05 PM
LesMyer's Avatar
Of course but that is only wishful thinking - put a test gauge on it before the engine is damaged.
Old Jan 30, 2017 | 06:24 PM
rockp2's Avatar
I'd agree with Lesmyer. Before running the engine any more, get a loaner test gauge from the auto parts store and put in place of the oil pressure sensor. Then run your engine and read the test gauge. You don't know which direction to go until you do the things that will be known good (or bad). The test pressure gauge takes all electronics out of the equation and you'll know for sure or not if your oil pump is working. If it is, then you can start addressing a possible cluster or wiring issue. But check the pressure before doing anything more. Very important.
Tuna
May 19, 2014 09:08 AM
jaystoy
Jun 9, 2012 01:56 PM
TheNasty0ne
Dec 7, 2010 03:23 PM
rhaig
Nov 22, 2009 07:28 PM
vaportrail
Aug 25, 2009 09:49 PM
