no third or fourth gear! what could it be?
Old Jul 20, 2007 | 03:16 PM
GMdesigner's Avatar
GMdesigner is an unknown quantity at this point
Default no third or fourth gear! what could it be?
hey guys, My '95 blazer 4.3L 4WD suddenly lost third and fourth gear. Could the solenoids be the cause, or is it something like a 3rd 4th clutch failure? If it were the solenoids, would the transmission go into a safe mode and only allow third gear to work? If so, I think I can rule that out and assume it needs a soft rebuild. Correct? Any fast advise is helpful. Also it is a 4L-60E trans.
Thanks
Old Jul 20, 2007 | 06:08 PM
jims3000's Avatar
jims3000 is an unknown quantity at this point
Default RE: no third or fourth gear! what could it be?
if it is a electronic controled trans then it may be the shift solenoid or just simply a resistor i would suggest buying a transmission manual i have rebuilt mazda trans that are electonic and they are not that hard to rebuild a transmission shop is going to charge you a arm and a leg to rebuild it just because it is electronic.some trans shops will just replace the bad electronic part and tell you they rebuilt it.if your trans never slipped and it just suddenly lost 3rd and 4th then i would say it was electrical. one thing to consider on electronic transmissions is they are wired into the truck ecm as well as its own ecm they work off of the speed you are going and the engines rpm.
Old Jul 20, 2007 | 07:43 PM
hillbillyinOhio's Avatar
well, if your tranny is going bad, 3rd gear is usually the first to go, at least from what I have seen. When was your last tranny flush/fill and filter???
hillbillys10
Oct 6, 2014 07:41 PM
filtalr
Aug 6, 2014 06:29 PM
cide
Apr 3, 2009 03:28 PM
hammer3478
Mar 12, 2008 03:49 PM
tom04841
Jun 26, 2007 11:36 AM
