No transmission
Old Jul 17, 2013 | 11:34 AM
The purple wire at the starter solenoid comes from the neutral safety switch, (on the transmission) which only activates the solenoid/starter when the transmission is in neutral or park only. Applying battery voltage to the purple wire will activate the starter. On the driver side, near where the transmission shifter would be, there is a wire harness that would connect to the neutral safety switch, you'll find the purple wire there.
Old Jul 17, 2013 | 08:24 PM
Kberven65's Avatar
Kberven65 is on a distinguished road
So that is under the vehicle correct? What's the best way to get power to that purple wire?
Old Jul 17, 2013 | 08:34 PM
Jumper wire from battery positive to the purple wire, either at the starter solenoid, (attached to the starter) or at the neutral safety switch connector.
Old Jul 17, 2013 | 08:41 PM
Kberven65's Avatar
It's the little wire right? And will the starter just spinning or do I start it like normal?
Old Jul 18, 2013 | 08:07 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Once the starter is enguaged it should turn the engine over so it should be normal.
Thanks Captain for filling in the rest of the details about the nss.
Old Jul 18, 2013 | 08:44 AM
Kberven65's Avatar
I know once the starter engages it turns the engine over....I'm asking if the direct power wire I run to the battery will make the starter run constantly
Old Jul 18, 2013 | 02:56 PM
Turn the ignition to the RUN position, then apply battery voltage to the purple wire to engage the starter. After the engine starts, remove the voltage from the purple wire.
Old Jul 19, 2013 | 12:16 PM
Kberven65's Avatar
Thanks I figured it out...now it turns over and now I gotta figure out why it run....what would be the first thing you would check? I don't think I hear the fuel pump kicking on
Old Jul 19, 2013 | 01:14 PM
Check fuel pressure and leakdown. If fuel pressure is between 55psi and 61psi, the pump is running.
Old Jul 19, 2013 | 04:25 PM
Kberven65's Avatar
I know how to check fuel pressure how do I check for leakdown thanks again
