Normal Tranny Operating Temp??
I have a 96 blazer 4x4 with a 4L60E tranny in it and it has gotten warm before so i changed the fluid and put and aftermarket tranny cooler on it and i also installed a transmission temp gauge and i was wandering wat the normal operating temp was?
I have glowshift trans temp and it sits about 140 give or take. But hot day (80+) mine will rise to 180-200 on the freeway when Im fighting for position, lol! Hope it helps!
Note: The rule of thumb I was told was; temp should sit about 80 over abient (experts correct me if im wrong?).
NOTE: B-A-R-B-E-D is not a bad word ???
Most run of the mill ATF brands are good to about 200*F before oxidization sets in and breaks down the fluid. The newer synthetic fluids are good to 230-250*F. The fluid needs to reach around 120*F or may be a little higher (I cannot remember exactly) for the PCM to be happy and keep the torque converter locked in when it is supposed to be. Overcooling the transmission fluid can cause lower MPGs due to the TC staying unlocked as the PCM tries to heat up the fluid.
my sensor is in my transmission so it may read warmer like you said. I think the reason mine reached 180 that day was because it was about a 2 hour drive with alot of stopping and starting and some interstate driving and it was about 85+ that day.. i pulled a small 5x8 trailer with a riding mower and push mower on it this weekend with temps around 70 and it only reached 160.
matt4x4
Apr 25, 2015 03:14 PM
stormyd
Jan 30, 2015 07:35 AM
Tinted
30
Feb 15, 2011 12:40 PM
theonetruetom
Jan 31, 2011 10:39 AM
hubert hefner
May 12, 2010 05:55 PM
