Normal Tranny Operating Temp??
Old Apr 27, 2009 | 06:59 PM
dewinkle03's Avatar
dewinkle03 is an unknown quantity at this point
Default Normal Tranny Operating Temp??
I have a 96 blazer 4x4 with a 4L60E tranny in it and it has gotten warm before so i changed the fluid and put and aftermarket tranny cooler on it and i also installed a transmission temp gauge and i was wandering wat the normal operating temp was?
Old Apr 28, 2009 | 01:48 AM
bandidolenny's Avatar
Just take it on a nice easy freeway cruise... that will be the normal operating temp. Then when you are in heavy traffic, off-roading, etc... you will know when things are getting hot.
Old Apr 28, 2009 | 03:37 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
I have glowshift trans temp and it sits about 140 give or take. But hot day (80+) mine will rise to 180-200 on the freeway when Im fighting for position, lol! Hope it helps!
Note: The rule of thumb I was told was; temp should sit about 80 over abient (experts correct me if im wrong?).
Old Apr 28, 2009 | 09:01 PM
dewinkle03's Avatar
my gauge is a glowshift too...mine sits about 140 too but i took it on about a 2 hour drive on a 85 degree day and it got up to 180 so i didnt know if that was too hot or not cause i was used to it staying around 140.
Old Apr 28, 2009 | 09:03 PM
dewinkle03's Avatar
where did you get your 2" suspension lift at?
Old Apr 28, 2009 | 11:39 PM
Where is your temp sender mounted? Mine is mounted in the line between my rad cooler and aftermarket cooler. It was just the easyest spot for me to cut the line and add a 3/8 ****** 1/4NPT T for the sender(used a 1/4 to 1/8NPT Reducer). If the sender is in the trans it would proly read hotter. I figure mine is a good average, lol.
NOTE: B-A-R-B-E-D is not a bad word ???
Old Apr 29, 2009 | 12:18 AM
okvortec's Avatar
Mine also sits at 140ish unless I go on a long drive then for some reason it hit 160.. not 180 though.
Old Apr 29, 2009 | 09:43 AM
Most run of the mill ATF brands are good to about 200*F before oxidization sets in and breaks down the fluid. The newer synthetic fluids are good to 230-250*F. The fluid needs to reach around 120*F or may be a little higher (I cannot remember exactly) for the PCM to be happy and keep the torque converter locked in when it is supposed to be. Overcooling the transmission fluid can cause lower MPGs due to the TC staying unlocked as the PCM tries to heat up the fluid.
Old May 4, 2009 | 08:50 PM
dewinkle03's Avatar
my sensor is in my transmission so it may read warmer like you said. I think the reason mine reached 180 that day was because it was about a 2 hour drive with alot of stopping and starting and some interstate driving and it was about 85+ that day.. i pulled a small 5x8 trailer with a riding mower and push mower on it this weekend with temps around 70 and it only reached 160.
matt4x4
Apr 25, 2015 03:14 PM
stormyd
Jan 30, 2015 07:35 AM
Tinted
30
Feb 15, 2011 12:40 PM
theonetruetom
Jan 31, 2011 10:39 AM
hubert hefner
May 12, 2010 05:55 PM
