Not lining up
Old Jan 26, 2010 | 01:59 PM
deegan26's Avatar
deegan26 is an unknown quantity at this point
Default Not lining up
I have a 96 s10 4wd with the 4L60E trans. earlier this month we swapped out the transmission for a junk yard one. when the test drive came i shifted from park into reverse and the light to tell you what gear youre in moved to R. Then i went to neutral and it stayed at R, then i went to OD and it moved no N and kept doing that all the way to 1st where it stayed at 2. when i went up from 1 to 2 it stayed at to then shift up to D went to D and shift to OD went to OD etc. etc. why is it doing that? and could that cause any problems?
Old Jan 26, 2010 | 02:08 PM
sparky672's Avatar
sparky672 is on a distinguished road
You'll have to adjust the shifter linkage.
Old Jan 26, 2010 | 02:13 PM
deegan26's Avatar
but would it be a problem in the future if i didnt adjust anything and just let it be? haha
Old Jan 26, 2010 | 02:16 PM
sparky672's Avatar
If your indicator light shows you in Neutral while you're really in Reverse or Drive, etc... could be disastrous.
Correctly adjusting the linkage will take you five minutes.
Old Jan 26, 2010 | 02:24 PM
deegan26's Avatar
okay would i have to go into the pan to adjust it then?
Old Jan 26, 2010 | 02:33 PM
sparky672's Avatar
It's external.... you disconnected/reconnected it when you changed the transmission.
MattMcF
Jul 1, 2012 12:53 PM
HHH6024
Jun 24, 2011 01:47 PM
nathanfoudray
Mar 29, 2011 07:53 PM
t.lyttle
Jun 19, 2009 07:31 PM
coplinb
Mar 29, 2007 11:35 PM
