NP208 Rear Output Shaft Bearings.
Old May 30, 2011 | 10:50 AM
oisinirish's Avatar
Default NP208 Rear Output Shaft Bearings.
Now that this hase become the daily driver we are steadily working through new issues.
The bearing(s) on the rear output shaft are shot, pretty sure. There is lateral play in the shaft and we've another leaking seal.
My questions are: Is it worth just replacing the two bearings, bushing and seal? Or should I do a complete rebuild?
I can just remove the rear extension case and r&r the bearings and bushing correct?
Old Jun 26, 2011 | 10:53 AM
oisinirish's Avatar
Any opinions?
Can the entire "rebuild" kit be completed in one day? I do not have a press, vice or puller.
Old Jun 26, 2011 | 06:20 PM
I would do a complete rebuild while you are in there.
What I would recommend is picking up another NP208 and rebuilding that, then just doing the swap when you have the time.
Old Jun 26, 2011 | 10:50 PM
oisinirish's Avatar
Was thinking along those lines myself. The vibration has caused the u-joints on the rear axle yoke to shift, heavy duty u-joints with no outside clips, and create MORE vibration.
I'm gonna need a dentist soon to replace my fillings.
Old Jun 27, 2011 | 01:03 AM
jjsmith1228's Avatar
jjsmith1228 is on a distinguished road
Exclamation need help asap
i have a 2000 blazer and to day it started taping and i dont know why? the oil is fine what can i do to fix it
Old Jul 5, 2011 | 10:00 PM
Jerry P's Avatar
Jerry P is on a distinguished road
Unhappy NP208 for 1986 K5
I have a 86 Blazer with 700R4 and 4WD, i have a problem with the transmission or actually i think it is in the transfer case. I can be traveling along and the transmission seems to go into neautral, i can shift into 4WD and move just a couple feet and then back to 2H and every thing is ok for a short period of time.. Any suggestions on what is causing the problem and how to solve it?
Jerry
Old Jul 23, 2011 | 09:27 AM
oisinirish's Avatar
Well, what appeared to be lateral play in the rear output shaft is really end play. I did not have the drive shaft disconnected when I checked the first time.
How much, if any, end play should there be? Okay, .0027" max endplay. How the he double hockey sticks to I measure that?!
We now have another leaking seal. Leaking around the shaft at rubber of the seal. So I know it's not the yoke plug or case/seal housing.
Oh. And there does not seem to be any play in the slip yoke to shaft.
3D_Illustrator
Apr 21, 2014 11:49 AM
WOMKPorkchop
Dec 30, 2013 04:16 PM
1sttimejimmyowner
13
Nov 13, 2012 07:24 PM
dudevoit
Mar 8, 2011 06:14 PM
duffy47
Mar 21, 2009 06:50 PM
