O2 Sensor Help!!
Old Jun 2, 2013 | 02:25 PM
Joseph's Avatar
Joseph is on a distinguished road
Default O2 Sensor Help!!
Hey People,
I'm a new poster and since I found these forums I have been meaning to get these codes and see if anyone here can lend a helping hand.
Anyway I have searched and searched to see if my issue was already posted and as far as I could tell no one has made a post that explains my issue completely anyway. I bought my 1998 Chevy Blazer LT 4wd 4Door a little over a year ago and since I bought it I have had O2 sensor codes on it and here they are P0147, P0135, P0155, and P0300, The truck doesn't have a rough idle, i get correct gas mileage and the truck starts right up without any issues any and all help would very much appreciated.
And as a side note over the last 3 days only when I pull into my drive way the oil gauge drops down to 0 from the usual idle of 40 and when I put it into park it goes back to 40.
Thanks Joe
Old Jun 4, 2013 | 05:59 PM
Aeromaster's Avatar
Aeromaster is on a distinguished road
Check the connector at the o2 sensor in question. i chased o2 codes and replaced the same one twice till I discovered corrosion at the plug contacts. A bad connection will throw codes like heater circuit malfunction. Try checking the electrical contacts at the O2 pigtail, then reset the engine light.
Old Jun 4, 2013 | 10:42 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
none of your heaters are working, check wiring. I wonder if they have a common ground or the same power source?
Old Jun 6, 2013 | 08:51 PM
Joseph's Avatar
Thanks alot guys I'll be trying both suggestions this weekend
Old Jun 16, 2013 | 04:56 PM
JIM MACGILLIVRAY's Avatar
JIM MACGILLIVRAY is on a distinguished road
After towing my 2700 lb trailer ,with no lack of power issues, I noticed for 1st time since installing engine 4.3 that I now have a check engine light stareing at me. I disconnected battery and it didn't erase the light. I know that o2 sensors can be the cause ,but mainly what else causes check engine light most commonly ? I will have the codes brought up at a service center, I have an auxiliary cooler for Rad. so heating up shouldn't be an issue, I'll post my finding after diagnostics, thanks for anything, Jim
Old Jun 17, 2013 | 07:54 PM
An update here regards my situation previously engine light. I decided, before going to service center to OBDI the code , that I would give it another try to erase the light by removing both battery cables and this time it made the difference , the light went out after 15 min. cables off and remained off so far I drove it and still off . the first time I just removed the ground cable and light stayed on. I hope this perhaps helps someone sometime ,worth a try anyway, however ,still don't why it came on in the first place. it seems that it was showing temp. gauge slightly up a wee bit than usually after the trailer tow. it had never come on before towing. if it ever comes on again I'll have a ready and read it.
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
