O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)question..
Old Jan 28, 2009 | 07:39 PM
daniel010's Avatar
daniel010 is an unknown quantity at this point
Default O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)question..
What sensor would this be cuz u see more then one sensor..Also i dont wanna ***** up the threads soo this is a dual question my truck idols at 500rpm should it be 800 ish how do i turn it up just with the throtle linkage thanks for you time guys ..Oh by the way itsa 96 blazer and i did search and couldnt really find anything I beleve its the one after the cat on the passenger side is that it
Old Jan 28, 2009 | 09:52 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Default RE: O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)question..
on mine i have one on each side of the engine on the pipes before they come together, then there is one after the cat, cant remember if ther is one before cat or not. but be shure you PB breaker them and run the truck to get the pipes hot, then be real carfull not to burn yourself but they will come out alot easyer. you may get them out cold but chances are youll strip them bad.
I have no answer about the idle mine idles at about a grand and i dont know if thats right or not, lol.
EDIT: oh yah, turn the truck off before you remove them, you just want the pipes hot.
Old Jan 28, 2009 | 10:41 PM
daniel010's Avatar
Soo what sensor is it haha
Old Jan 28, 2009 | 10:50 PM
If I remember correctly:
1,1 is drivers side
2,1 is passanger infront of cat
2,2 is passanger side behind cat
there on the exaust pipe, looks like a little tube sticking out, with wires on the end.
hope it helps.
Old Jan 29, 2009 | 07:18 AM
You do not modify the idle speed. It is controlled by the PCM via the IAC (idle air control) valve. Are you afraid that your truck will stall? You can clean the IAC valve and the bore it resides in relatively easily.
Old Jan 29, 2009 | 08:27 AM
daniel010's Avatar
where is the IAC valve ive noticed though my trothle cable is very tight or is that normal theres a lil but of slack
Old Jan 29, 2009 | 08:32 AM
Search does work...
IAC is on the drive side of the throttle body back a bit from the TPS sensor. It is mounted to the side of the throttle body with two torx screws. You may want to remove the whole throttle body and clean the entire thing.
Old Feb 1, 2009 | 10:39 PM
79cheyenne's Avatar
79cheyenne is an unknown quantity at this point
sensor 1 bank 1= driver side pre-cat, sensor 1 bank 2= pass side pre-cat, sensor 2 bank 2= pass side after cat. On obd-2 vehicles idle is set in the computer, AFAIK it can't be changed as long as everything is working properly it shouldn't need changed.
Old Feb 2, 2009 | 06:50 AM
There is no B2S2 sensor on these trucks.
In the 96-97, there are four sensors:
[ol][*]B1S1 == Driver side between the exhaust manifold and the "Y" in the y-pipe.[*]B2S1 == Passenger side between the exhaust manifold and the "Y" in the y-pipe.[*]B1S2 == Pre-cat sensor that is located between the "Y" in the y-pipe and the catalytic converter.[*]B1S3 == Post-cat sensor located directly behind the catalytic converter.[/ol]
bam_9_9_9
May 10, 2020 01:01 PM
FOGEL
Mar 26, 2013 07:24 AM
lorretta
Jul 10, 2011 07:55 PM
marine
Jan 28, 2010 07:04 PM
theeviltwinn
Oct 23, 2009 06:37 AM
