OBD1 OR OBD2
Old Feb 17, 2008 | 08:29 PM
newguy07's Avatar
newguy07 is an unknown quantity at this point
Default OBD1 OR OBD2
Is a 95 blazer obd1 or obd2?
im going to buy a scanner so when the check engine light goes on i can check the codes myself but im not sure if it will work because all of the scanners on ebay say obd2 is 96+
Old Feb 17, 2008 | 08:45 PM
Default RE: OBD1 OR OBD2
Neither. It is a combination of both. You will need a scanner that specifically states that it will work with '95 GM vehicles with an OBD2 plug under the dash.
Old Feb 17, 2008 | 09:11 PM
newguy07's Avatar
do you happen to know a place where i could get one?
Old Feb 18, 2008 | 07:50 AM
THIS LINK from Actron.com should shed some light on the subject for you.
If you can use the CP9001, it is only $30 from Advanced Auto, but it is a basic code reader, nothing more, nothing less. However, the CP9001 is only an OBD1 reader.
If you have the OBD2 connector, you really don't have many cheap options for being able to read the codes.
Old Feb 20, 2008 | 11:56 AM
kerander's Avatar
kerander is an unknown quantity at this point
I have used several OBDII readers and all have been able to read my 95.
jmaynard
Aug 5, 2014 01:38 PM
Majoraslayer
Jul 21, 2012 08:59 AM
Tortex53
May 7, 2011 11:54 PM
LarryDarnell
Sep 18, 2010 10:10 AM
jamez70
Aug 31, 2009 03:22 AM
