Ocalating RPM's in Drive?
Old Aug 2, 2011 | 10:35 AM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
Default Ocalating RPM's in Drive?
Hey all, OSS here;
I have an issue that is sometime there, sometimes not. The truck sometimes seems like it's on cruise control, where it'll coast for a long time. Floor mat isn't making the pedal stick.
Sometimes at around 50km/h, my RPM's will drop to 1100 (foot off the pedal) It'll then sit there for a up to 15 seconds, then sometimes drop to 600 RPM for half a second, then bounce up to 1100 RPM, settle there, and repeat. It moves very quickly, like an electrical issue. I do go 4x4ing. Maybe just some mud/dirt stuck up on the TPS?
-OSS
Old Aug 2, 2011 | 10:47 AM
Unless something goes really wrong inside the TPS sensor, it won't cause the throttle to hang. I would check the throttle body for smooth movement, that it isn't hanging up partially open. Clean the IAC valve. Check both the cruise & main throttle cables for smooth operation.
Old Aug 2, 2011 | 03:06 PM
pettyfog's Avatar
Also... I'd pull codes. See if there's any sensor failures stored.
And do a gentle wiggle/tug test on engine wiring harness and vacuum distribution. Had similar problem from a cracked plastic tee.
Off-roading also reminds of the vapor recovery system. Though a broken purge line shoulld throw a code, perhaps it's broken just right to give you this symptom.
mirrorimij
Jun 8, 2019 03:34 PM
Blade_24k
Feb 26, 2014 03:03 PM
lizzj70
Jun 23, 2010 06:57 PM
carterx
May 21, 2009 08:30 PM
2001Blazer4x4
Apr 20, 2005 12:09 AM
