oil change
Old Dec 6, 2007 | 12:29 PM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
Default oil change
i am now at the point unfortunatly in 1ft of snow having to change my oil..i tried yesterday but the drain plug will not come off, its liek they put gorilla glue on it can some1 please help and tell me the best ways to remove the plug with stripping???? id appreciate it
[/align]
Old Dec 6, 2007 | 01:27 PM
Banned
Default RE: oil change
anyone?
Old Dec 6, 2007 | 01:32 PM
Calm down there killer... No need to bump a post a mere hour after the first one.
Have you tried heating it? Not a ton of heat, but a bit...
Also, are you using the appropriately sized wrench/socket? I know that sometimes with drain plugs, a standard will fit better than a metric so try out a few different sizes to get the one that fits the best.
Old Dec 6, 2007 | 01:51 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
Ya heat it... if its stripped try some fluted bolt extractors, they work like magic!
Old Dec 6, 2007 | 02:29 PM
rriddle3's Avatar
I know of two different sized plugs that have been used on Blazers, a 12mm or a 15mm. I suggest a good box-end wrench for the job.
Old Dec 6, 2007 | 09:24 PM
Hanr3's Avatar
and if its on that tight use another tool to add leverage.
Old Dec 6, 2007 | 09:27 PM
Banned
how do i "heat the drain plug"?? thanks guys
[/align]
Old Dec 6, 2007 | 10:19 PM
Banned
is it a tool you buy to heat it?? im lost on that
[/align]
Old Dec 6, 2007 | 10:37 PM
WolfPack's Avatar
you/girlfriend/mom got a hair dryer?
Old Dec 6, 2007 | 10:42 PM
Banned
thats all it takes??? i dont have a garage so i gotta do it out side
[/align]
