Oil Change!
Old Apr 5, 2008 | 07:16 PM
elementalnature's Avatar
elementalnature is an unknown quantity at this point
Default Oil Change!
I have the basics down here: http://autorepair.about.com/od/regul...oil_change.htm - I checked the owners manual and it doesn't tell me how much I should put in. I have a 94 Blazer S10 V6 Vortec engine. Any help?
Old Apr 5, 2008 | 07:24 PM
thegr81's Avatar
Default RE: Oil Change!
Its 4 1/2 quarts.
Old Apr 5, 2008 | 07:26 PM
rriddle3's Avatar
I'm assuming that it's 4.5 quarts like on mine. The article you linked to - well, the first line of it is BS about letting the engine cool several hours before changing the oil. You want to have the engine run at full operating temperature for about 15 minutes to let the moistureget out of the crankcase and then change the oil while it's warm to make sure it flows out thoroughly. I usually give it about 30 minutes cooling while I raise the truck and collect all the things I neeed to do the change.
Old Apr 5, 2008 | 08:41 PM
Hanr3's Avatar
All the S10-Blazers are 4.5 quarts, although I always put in all 5 quarts.
Old Apr 6, 2008 | 02:04 PM
5qts in my Bravada as well to bring it up to the very top of the dip stick.
Hormisdas
Nov 27, 2012 09:42 PM
chris015
Jun 8, 2012 12:37 PM
zippy199
Oct 22, 2009 06:36 PM
todaresqSL2
Nov 10, 2008 01:47 PM
DSRJohnGTP
May 26, 2005 10:08 PM
