Oil in coolant
Old Feb 18, 2009 | 06:51 PM
marine3567's Avatar
marine3567 is an unknown quantity at this point
Default Oil in coolant
Hello,
I have a 1996 gmc jimmy with a 4.3.
problem:I was changing the oil and wile that was draining,decided to top off the coolant.
when I poured the coolant in the radiator it came out of the oil drain hole!The oil was milky as you already have guessed.
Do I have a cracked block or?
thanks in advanced.
Old Feb 18, 2009 | 07:43 PM
Default RE: Oil in coolant
Most likely cause is a failed intake manifold gasket, but if you just noticed it when you serviced the cooling system, you may have damaged a LOT more.
Old Feb 18, 2009 | 10:53 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
If the oil looks like a frothy milkshake, it's time for a teardown.
Old Feb 18, 2009 | 11:04 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
Blown Head Gasket?
Old Feb 19, 2009 | 06:42 AM
samuknow's Avatar
samuknow is an unknown quantity at this point
That condition cost me an engine replacement not too long ago. DO NOT RUN IT LIKE THAT. pull the intake and go from there.
Old Feb 19, 2009 | 06:46 AM
bandidolenny's Avatar
Did your truck ever overheat? Is your radiator in decent shape? Runs fine otherwise? Dont spend your income tax refund just yet...
AcerDeucerQ
Dec 3, 2012 06:29 AM
babeba67
Apr 1, 2011 10:54 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
jimhens82
Dec 23, 2009 04:50 AM
todaresqSL2
Nov 10, 2008 01:47 PM
