Oil in coolant but not vice versa
Hey all got a 95 Jimmy 4x4 with 128k on it with oil in the coolant. No coolant in oil or trans. What are the odds its just the cooler line in the radiator tank? No external leaking/weeping that i can see anywhere. Plugs all looked good.
if oil got into the coolant, there's no reason that coolant won't find it's way into the oil.
i'd get that fixed ASAP, if you already haven't.
lord knows a new/repaired rad is waaaaaaay cheaper than an engine rebuild!
I would say that the reason theres oil in the coolant and not the other way around is because you have a blown oil cooler. The pressure in the oiling system is much higher than in the cooling system, hence the coolant wont be able to force its way into the oil.
you don't think the hot coolant won't force it's way into the oiling system when the truck is shut off? hence having no oil pressure to keep the coolant @ bay.
IDKAU, but i'd be spending a little $ now-for a little down time-compared to alot of $ for a major pit stop.
babeba67
Apr 1, 2011 10:54 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
pmezo
Feb 6, 2009 10:34 AM
dist6blazer
Jan 15, 2008 10:47 AM
